Civil3D Section Views and Section Sheets
ipfeiffer
ipfeiffer
I am trying to get 4 section views per section sheet (I can only get 3).  I tried to make a template for the cross section sheet, but having trouble.  I tried adjusting sheet group plot style in the array, but still not coming up with what I want.  There should be lengths of 1.2' between section views. This is a 5 scale template. Thanks.
SoaresASBCAD
Hey @ipfeiffer
The number of section views per sheet is controlled by the Section View Group Plot Style and the available space in the sheet template. Since you need four views at 1:5 scale with 1.2' spacing, try reducing the section view height/width in the plot style or increasing the usable area in the sheet template. If Civil 3D still only places three views, the current plot style dimensions likely exceed the available sheet space.
ASoares
obulesub
Hi @ipfeiffer,
Please let us know if you require any further assistance regarding this matter. If any of the provided comments helped resolve your request, kindly mark the relevant response as the accepted solution. Alternatively, if you found a solution through another method, we would appreciate it if you could share the details with us.
Obulesu | Community Manager
obulesub
Hi @ipfeiffer
Good afternoon! has the response from SoaresASBCAD helped address your request? If so, please mark it as the accepted solution. If you require any further assistance regarding this matter, please let us know, and we will be happy to assist.
