2D StickLogs Stuck at 0 Elevation
sbondEVRFH
sbondEVRFH
Community Visitor
Community Visitor
Hi All
I have the geotechnical module and when creating sticklogs the graphic remains stuck on a 0 elevation. The borehole points themselves are at the correct elevation. I have gone through the point groups and have set everything "use surface elevation" and nothing appears to be flattened.
Due to this issue the program will not generate 3D sticklogs.
I also noticed that my alignments are running on 0 elevation but that doesnt seem to be an issue for the profile views etc.
I am unable to see any borehole headings in prospector tab, other than the general point group for boreholes.
Where can I look up the sticklog group properties or how can I fix this issue?
SoaresASBCAD
This usually indicates that the borehole collar elevations are not being read by the Geotechnical Model, even if the COGO points have the correct elevations.
I would check:
  • Whether the Borehole Collar Elevation is 0.000 in the Geotechnical Manager.
  • If the Geotechnical > Boreholes node is missing in Prospector, which may indicate the geotechnical model/database is not properly linked.
  • The Sticklog Group settings to ensure it is using the borehole collar or surface elevations instead of a fixed elevation.
Since your alignments are also appearing at elevation 0, it may be a broader issue with the geotechnical model or drawing references rather than the sticklogs themselves.
ASoares
