05:40 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having a problem with Creating my section views with the levels being shown at the correct locations.
I keep playing around with the weeding value and I can never find one that shows the levels at the correct locations.
I don't quite understand weeding to be honest, it seems like quite a convoluted way of setting which points you want to show a level in the section bands. Wouldn't it just be easier to assign the where you want to display levels by point code, for example, showing level at the edge of carriageway point code, or the back of verge point code.
I've uploaded a screen shot of a section with ordinance line set at a weeding value of 0.15 (Ive tried weeding up to 100 with no success) As you can see the ordinance lines are inconsistent, some at back of kerb, some at the bottom, also random lines in the verge and carriageway.
Hopefully someone here can enlighten me as to what im doing wrong, because I cant believe Autodesk would make a system that limits your ability to show the information you want to show.
Regards
Dan
