problem with WMTS and WGS84
Hi
I've tried to add an open WMTS Server, but I allways not match:
For reference: I'm using Portable Basemap server v3.1
How can I solve this problem?
  • WMTS
Pointdump
Hi Amin,
I've never used Portable Basemap Server, so I have no idea how that works.
Your 27M shift looks like it's shifting to SouthEast which screams Datum Shift. Verify the Coordinate System your published Data is in.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Thanks for your reply
But the map is not shifted, and the map coordinate are correct.
WMTS is also corrent because it is displayed correctly with ArcMAP.
Do you know suitable WMTS for Iran?
Pointdump
Amin,
"But the map is not shifted, and the map coordinate are correct."
OK, I'm confused then. More details please on the problem.
"Do you know suitable WMTS for Iran?
No, sorry, I don't.
Dave
Dave Stoll
Las Vegas, Nevada
ChicagoLooper
I don't use Basemap Server 3.1 either but I can tell you, by default Google Maps is referenced to LL84 (EPS G4326), not WGS.Pseudo Mercator (EPSG 3857).
In your ArcMap program, what is ArcMap 'reading' as the native coordinate system of your WMTS connection? Can you verify  ArcMap is reading WGS.Pseudo Mercator, EPSG 3857? Upload a screenshot displaying WGS.Pseudo.
Start from a brand new, clean metric template then:
  • Assign the coordinate system UTM84-40N (EPSG 32640).
  • Connect to your WMTS (Edit the coordinate system of WMTS connection to WGS.PseudoMercator).
  • Use zoom and pan commands to focus on your area.
  • Cut and paste from your first drawing to this new one.
Chicagolooper
Hello
thank you
But my problem was not solved.
I filmed the steps I do. Thank you if watching it
Video:
http://badrkhaniasl.ir/Rec%200001.mp4
Pointdump
Amin,
Thanks for posting your video. Nice music! Using your link, I got "failed to connect" in both Civil 3D and QGIS. Is Portable Basemap Server a paid subscription service?
How did you get from zoomed in at 728527.514,4024348.683 to seeing the whole earth at 1:48?
Dave
Dave Stoll
Las Vegas, Nevada
