- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I haven't changed how I've been doing these things for the last 3 years. Sometimes it works, sometimes it doesn't work right. Like this example here. I created the surface, created an alignment, created the sample line. My cross section comes out only half complete. Unfortunately I still have problems with this site and can't add an attachment to show you guys. The best I can do is explain...ugh. But the cross section shows up but it's missing the info of the actual surface. It shows the grid lines and where the grid stops is the surface but doesn't show the surface line from left to right on any of the cross sections. Just shows blank areas instead. I hope someone can understand what I'm trying to explain because this gets frustrating when it happens. I've already redone my alignment and sample lines multiple times but still nothing. AGAIN...I can't get this site to work right. I've cleared my history and cache like someone mentioned before but the whole message board shows up blank. Also have problems attaching anything. I can't copy and paste the pic into this message because it won't let me do that either. Someone mention it could be explorer but since I'm at work, this is the only browser I'm able to use.
Rob
HP Compaq 8100 Elite
Win 7 Pro SP1 - 64Bit
8GB RAM
i7 860 @ 2.80 GHZ
AutoCad Civil 3d 2012 SP1
8GB RAM
i7 860 @ 2.80 GHZ
