I have a problem with the hardware acceleration. All processors have built-in GPU (I have processor Intel Core I5 3570K). My local GPU is Radeon. AutoCAD Civil 3D for hardware acceleration use not what I need. I can not change it in AutoCAD window. Civil 3D choose Intel, but I need Radeon.
I attached screenshot that demonstrate this problem. On videocard Radeon I installed all latest drivers from 22 June 2015.
I also try to shut off Intel Videocard from device Manager. But it not help. My system is Windows 7 64Bit
Solved by Karadzhaian_Eduard. Go to Solution.
Problem solved!
First I tried to set up file acad.exe through the center of the graphics card settings (AMD Catalyst Control Centre - in my case).
But nothing good came of it.
So I decided to turn off the Intel graphics card at all of Bios.
I found the " main display " . Put the PCI Express ( and stood iGPU - the same Intel).
But it is not helped.
The following option was "iGPU Multi-Monitor" - it was necessary to further disable it .
And all done!
Now the load is on the Radeon !!!
Tested and at the 15th and the 16th version of Civil 3D.
Эффективная работа в Civil 3D
http://eduart-k.blogspot.ru
