Civil 3D Forum
Problem with Bands
3 REPLIES 3
GreeneSWCD
148 Views, 3 Replies
Problem with Bands
I can't get a band under a profile to show elevations for my existing ground and my design ground.  I've found the table where you input the Profile1 and Profile2, but only getting one number below, not a pair of numbers stacked.
I could really use a fresh video showing how to construct a band from scratch, along with what to check for the current problem.
Labels (1)
3 REPLIES 3
MMcCall402
in reply to: GreeneSWCD
My guess is that the band style isn't set up to show the elevations from two profiles.
Check/edit the band style you have to add the elevation from the second profile or switch to a band that is already set up to do this.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
GreeneSWCD
mark, I can't get to the screen you are showing.  I must be starting in the wrong place?  Can you walk me to there?
MMcCall402
You can get there thru Toolspace.
Mark Mccall
CAD Mangler
Linkedin
Rail Community
