I can't get a band under a profile to show elevations for my existing ground and my design ground. I've found the table where you input the Profile1 and Profile2, but only getting one number below, not a pair of numbers stacked.
I could really use a fresh video showing how to construct a band from scratch, along with what to check for the current problem.
Solved by MMcCall402. Go to Solution.
My guess is that the band style isn't set up to show the elevations from two profiles.
Check/edit the band style you have to add the elevation from the second profile or switch to a band that is already set up to do this.
mark, I can't get to the screen you are showing. I must be starting in the wrong place? Can you walk me to there?
