Civil 3D Forum
Problem pasting datum surface
2 REPLIES 2
mzurek
274 Views, 2 Replies
Hi All,
I'm having some issues pasting the datum surface of a roadway corridor model onto an existing ground surface model. When I attempt to paste the surface, (which displays just fine in the object viewer) I get an error telling me that my datum surface is corrupt. Does anyone have any idea how to solve this problem??
Mike
2 REPLIES 2
cwr-pae
in reply to: mzurek
I had a problem with this once, I can't remember cause or cure of the top of my head. Can you post the drawing?
Assuming you have closed and restarted all drawings and C3D and then reopened and tried again:
Are you pasting both surfaces into a third? You can't paste a corridor surface into a surface the corridor references.
Verify that neither surface has a transform (been moved) listed in the surface properties.
Try making data shortcuts and inserting them into a separate drawing. IF that works try the paste there.
mzurek
in reply to: cwr-pae
Thanks for your help 🙂
I was trying to paste on to the same surface that I was targeting...
Rail Community
