PROBLEM AUTOCAD CIVIL3D DISPLAY
A GOOD AFTERNOON
I WANT TO PREACH ABOUT THE CIVIL3D 2018 SOFTWARE.
CONSTRAINTS ON THE SOFTWARE PRODUCE DISPLAYS ON EACH LOGO TOLLSPACE - EACH COMMAND IS NOT PERFECT
Pointdump
Hi @Anonymous,
Welcome to the Autodesk Forums.
More details please. Are you having trouble importing points? Can you post the Point File?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
SORRY FOREVER, THE PROBLEM IS NOT AT THE IMPORT POINT BUT THE TOOLSPACE LOOKS ARE NOT GOOD (LOGO ON EACH COMMAND IS TOO SMALL)
Udo_Huebner
Are you using a 4K monitor?
Civil 2018 is not yet able to display scaled icons in all dialogs at very high resolutions.
Gruß Udo Hübner (CAD-Huebner)
Pointdump
@Anonymous,
As Udo says, if you have a 4K monitor this is a problem. Still not fixed in 2020. Right-click the program icon on your desktop and select Properties >> Compatibility >> Change high DPI settings >> Override high DPI scaling behavior >> System.
Dave
Dave Stoll
Las Vegas, Nevada
YES SIR
I USED THE 4K
MEANS THE BACKGROUND OF THE APPLICATION DOESN'T SUPPORT ITS RESOLUTION SO HIGH AS MYSTER, NOT BECAUSE OF THE COMPUTER USED
THANK YOU MORE MYSTERS
I ALREADY TRIED THE MYSTER, STILL NOT NORMAL MY TOOLSPACE DISPLAY
