Pressure pipe Compass is not shown in ribbons
Beka_Tchigladze
Advisor Advisor
Beka_Tchigladze
I Have one boring problem compass is not shown in panels when I use pressure pipe creation here is an images
it is not in the list of show panels but it is in CUI, how can I force civil to command this feature??
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
What version of C3D are you using?
In C3D 2021 I think it has to do with whether it is a pipe run (shows) or a part based pressure network (doesn't show).
You've probably got a parts based network, which is the way previous releases built a pressure network, since pipe runs don't work well.
Beka_Tchigladze
Here is documentation is that what you were talking about?
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Yes. You should know that there are two updates available for your C3D. Use the Autodesk Desktop app to see/install them.
So, I think if you have a parts based network then you will not see the compass. If you have a pipe run, you will see the compass. I do not know why it behaves like this.
Beka_Tchigladze
@Anonymous
Update works perfectly thank you!!!
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
