I have a dwg of municipal sewer system, streets etc and need to create polygons for catchment areas and attach data to the polygons (catchment structure ID, area, name) so that I can export to shapefile so another user with Bentley ModelBuilder can import the shapes & data. I'm looking for the proper steps/workflow to do so, I've been trying to use the tools in Map3D (2014) without much luck, any suggestions would be greatly appreciated.
Solved by tcorey. Go to Solution.
This should help:
https://www.youtube.com/watch?v=gSpyEso92xQ
Best regards,
Tim
