Point Groups Propagating
C3D 2019.2 Win10
We hired a consultant to set up the city with templates, etc. The survey template has several predefined point groups. They are copying themselves by adding a numeric suffix and so, even though I have only a few point import operations, and only 21 total points, I now have over 100 point groups in the dwg. Many, like in the screen capture, are empty. There are not sanitary points at all. Where is the setting to keep point groups from propagating?
AllenJessup
The usual cause of this type of numbering is copying and more particularly pasting objects. In you case points. However it doesn't sound like that. Do you insert drawings that already have the defined point groups in them?
Allen Jessup
CAD Manager - Designer
Usually these additional point groups with the numeric suffix are just duplicating the data filters (point description).  If this is the case, there is a lisp routine that will remove these phantom point groups.
I didn't write it, but neither have I found out who did or I would give attribution.  I will say thank you, because it helps us a ton.
No, it's a pretty straightforward create a dwg from template then eventually import points via the Insert tab (not survey database).
we are converting from microstation to autocad - maybe then converted dgn elements are bringing in strange behavior, I don't know.
Thanks. I will use the lisp. To date I have just been selecting the hundred extra point groups and deleting. It's odd how it keeps happening, though.
AllenJessup
You could test that by running Drawing Purge on the drawings. It should strip out any DGN data.
Allen Jessup
Jeff_M
Looks like my work, with a little modification by others.
https://forums.autodesk.com/t5/civil-3d-customization/delete-point-groups/m-p/5272069#M9465
You're welcome. 🙂
