Point file << No point file format found error.>>
Hi Guys!  I am having an issue importing a point file to my civil3d 21018.  They were created manually to an Xl sheet.  I keep getting an No point file format found error. do I need to edit my xl sheet or something?  Thanks!
pis below
Point file << No point file format found error.>>20180204_161953.jpg20180204_162307.jpg
Pointdump
Edu,
Please post your Excel file. Is it PNEZD or PENZD? In what format is the Point File when you attempt to Import into C3D? CSV, TXT?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Jeew-m
Dear Friend,
As Dave has pointed out it is better to upload your excel file. Also please make sure the following.
You should save the excel file in csv format with comma delimited csv.
Also when you insert the point file make sure the excel file is not opened. It should be closed.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
yes, thanks guys.  It was the comma delimited I was having the issue with.  I brought it in as an XL, and then exported as a .txt file 🙂
what a pain lol
