Point Cloud to CAD Drawing
varunaditya_mittagunta
Observer Observer
Message 1 of 8
Observer
Observer
Hey,
Good afternoon, I'm trying to create a CAD drawing of a power line tower from LiDAR point cloud.
I have converted the LAS into .rcp and imported into Civil3D. Are there any videos that show how to trace the point cloud to get a 3 wireframe model of the tower from point cloud?
Is C3D the right software for this application? Any help is appreciated greatly. Thank you for your help.
Best regards,
Varun Mittagunta.
Replies (7)
Message 2 of 8
rl_jackson
While in Recap did you classify the ground data?
I use the Infraworks to process the data and then bring that data to C3D. I try to limit the Point Cloud in C3D as it's not geared towards that.
Rick Jackson
Survey CAD Technician VI
Message 3 of 8
Wojtek_Garczewski
Hi @varunaditya_mittagunta
This can be done in InfraWorks with Linear Feature Extraction:
https://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-0D6EE499-32D7-4D75-BF8C-6D624DC06FAD
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
Product Owner for Civil 3D
Civil Engineering Solutions
Message 4 of 8
andrewpuller3811
Depending on the density, Autocad can extract intersection lines and points from point clouds - see the help here - https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-C0C610D0-9784-4E87-A857-F17F1F7FEEBE
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Message 5 of 8
Wojtek_Garczewski
Additionally, you may try our new tool available on ACC.
Automatic Linear Extraction tool in ACC.
Wojtek G.
Message 6 of 8
TerryDotson
I'm trying to create a CAD drawing of a power line tower from LiDAR point cloud.  I have converted the LAS ...
You could plot the tower points (as fairly lean DbPoints) in CAD using DotSoft LidarTools Freeware on Autodesk App Store then play connect the dots with CAD objects.  Be sure to specify classes 13, 14, 15, 16 to eliminate ground points, etc.
Message 7 of 8
Observer
Observer
Terry Dotson,
Thank you for your time. Could you please elaborate?
Message 8 of 8
TerryDotson
One of the tools in that freeware plots AutoCAD points at the 3D location in the lidar file.  It allows you to specify lidar classes, the numbers I referenced are for high structures.  It also allows you to specify a rectangular window to limit the point to.  It may not be optimal, but the user could then generate 3dFaces or 3dPolys (Power Lines) by snapping to the points.  Once an area is done erase the point objects leaving the structure drawing, move on to the next area, etc.  Keep your point plots areas small and limited by class because too many points will bring CAD to a grinding halt.
