Civil 3D Forum
pls help, why these corridor lines are showing double layer
2 REPLIES 2
szs.edu.ytu
156 Views, 2 Replies
2 REPLIES 2
cwr-pae
in reply to: szs.edu.ytu
It looks as if one of them is from generated from a surface that has been moved (transformed). Check under surface properties, definition tab for a line with transform and remove it.
Jeew-m
I think this is because you do not have a frequency line on the corridor at this location.
Add a custom frequency line at the sample line location and check whether it solves the issue.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Rail Community
