It looks as if one of them is from generated from a surface that has been moved (transformed). Check under surface properties, definition tab for a line with transform and remove it.
I think this is because you do not have a frequency line on the corridor at this location.
Add a custom frequency line at the sample line location and check whether it solves the issue.
