please can you help me? what is the reason behind my Road Cross section?
mzkidus
mzkidus
Joe-Bouza
Not seeing the correct profile and targets?
Joe Bouza
lim.wendy
Hi Kidus,
Welcome to the Civil 3D forum. Thanks for reaching out to the forum. As Joe pointed out, it seems that your section view is not displaying the cut and fill daylight lines, and the section itself is truncated.
I will examine the surface from which the cut and fill daylight is being generated and also verify whether a surface boundary is defined. It's important to note that if the section view extends beyond the surface limits, the cut-and-fill daylight might not be visible.
If you can, please share your DWG file with us. I am confident that some of our members will be able to provide you with a prompt solution.
Here are some additional tips to consider when posting your question:
Write your post with as much detail as possible to fully convey your question or issue. Include operating system, any actions leading up to the issue (if applicable), and any other issues you think may help. Try to include your product, version, and updates as well.
Embed/Attach a Video to get the most accurate solutions from the community. Often, members share videos to show other members how to perform a task or solve an issue.
This helps community members who are experienced with your product identify your post.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
mzkidus
please can you help me? what is the reason behind my Road Cross section? I attach my Civil 3d File Please Comment thank you
Joe-Bouza
make sure your corridor is rebuilt. It was not when I opened it
I suspect the limit of EG-ak is not wide enough for the sub assembly to reach. also, there are several corridors in here. Who is who in the zoo?
Joe Bouza
