How do I create excel table in civil 3d?
jeff.wangD95HG
Message 1 of 10
jeff.wangD95HG
https://youtu.be/12JmZWy6rrE?t=1190
how do I create a table that is shown in the video?
at 19:51
The author said he will go over it some other session but I checked the playlist and its not there
Replies (9)
Message 2 of 10
Jeff_M
To create a Table, enter TABLE at the command line...
Jeff_M, also a frequent Swamper
Message 3 of 10
jeff.wangD95HG
ok thanks.
Do you happen to have instructions on how to modify it?
like changing it to 5x5
Whenever I google tables  only the blocks with table styles show up and this table is apparently go by a different system
ok nevermind apparently you can only do it from the creation menu.
Message 4 of 10
Jeff_M
You can add/remove columns and rows from an existing table. Click on a column/row and rt. click to get those options.
Message 5 of 10
Joe-Bouza
Not true
grip the table and all the modify tools are there: add rows add cols, ad cell style. The list keeps going. The long and shirt of it is you can modify everything post placement
Joe Bouza
Message 6 of 10
jeff.wangD95HG
ok thanks
Its basically like Excel spreadsheet then by the looks of it now that I've explored it further
Message 7 of 10
r.capper
Just to add that if you already have the table in Excel copy it then in AutoCAD Home  (on ribbon) > Clipboard > Paste > Paste Special (drop down) > Paste (radio button)and choose AutoCAD Entities will paste an AutoCAD Table that does its best to match the source with text, number, date formats etc in cells it creates. Paste Link > AutoCAD Entities will do the same with a link back to the excel source that updates if the data there changes
Robin Capper
Design Systems Manager
LDE Ltd
Message 8 of 10
neilyj666
It's also worth remembering that AutoCAD tables are totally different objects from Civil tables and that the vanilla AutoCAD table editing tools don't work for the Civil tables.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 10
Joe-Bouza
Correct
Joe Bouza
Message 10 of 10
Joe-Bouza
Correct
Joe Bouza
