ok, this is an interesting problem . . .. .
1. copy your plan view border (anywhere does not matter)
2. add the start and end stations for each plan view
3. you can use the north arrow to rotate you plan view border
4. use CHSP (changespace) to move your plan views into model space
5. align the plan view with your model drawing
6. use DVIEW to rotate the model, to match the first plan view border
7. use V (view) to create a named view for the plan view
8. Repeat steps 5, 6, and 7 - for each sheet plan view.
9. go back to your sheet tabs
10. unlock the viewport, and go to model space in the viewport
11. use V (view) to set the current view
12. go back to paper space and SAVE!!
13. adjust any text labels that are off
14. repeat for each layout tab.
not much fun - but it works!!
hard lesson learned - I have the same problem where i work; seems some techs will not change
even when they had this problem multiple times . . . . .
dynamic is great for some items, but the two that should work out of the box (otb) don't : ((
good luck
nonbeard13
