Pipes not showing in Network Layout Tools
victoriamilne1
victoriamilne1
Hoping this is an easy question.
I had a whole network of pipes in a drawing working
If I change the parts list to any of the others I can access all the pipes, it's just the one I need, and have already used that doesn't work. The structures seem to show up just fine.
If I go into the parts list it shows numerous pipes available so I'm not sure what the problem is.
Any suggestions would be greatly appreciated.
- I'm using AutoCAD Civil 3D 2018.
Thanks.
CivilFlow
Hi there-
I have got that before in previous versions at times.  My only workaround is to close Civil 3D and open dwg again...it should populate your list in the Layout Toolbar once you reopen.  I'm not sure why it does that.
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
victoriamilne1
I've already tried that but no such luck!
CivilFlow
Sorry to hear that!
Please try the fix presented in this thread from AKN:
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
I hope this helps.
Michael M. Carlson
CADD Manager
BushW
Hello @victoriamilne1
Sorry to hear that you are having this issue but, take a look at this solved <<post>> to see if this address the problem you are having. This post suggests reviewing your pipe network catalog location settings "Setnetworkcatalog" are correct. I hope this helps solve your issue.
Please hit the ‘Accept as Solution’ button if my post solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
victoriamilne1
This worked Wendell, thanks.
