Ok, here goes, I am having trouble swapping parts through my pipe network on an older job. I recently received a new computer and I am trying to edit a large storm and sanitary system project. I still have limited access to my old computer and I can edit the project through that machine but it happens to be a coworkers station now. I can view all my utility runs and I can view my parts list and both seem fine. when I try swapping part it does not change. I also cant edit the sump of any structure. I have already checked the path of the "setnetworkcatalog" for the pipes catalog and even copied from old computer to new computer and still nothing. I also have tried deleting my parts list to create a new parts list but that didn't work at all. when I go to add parts all I see is grid lines with no data. Any ideas are appreciated. Thanks in advance
Joe Bouza
Thanks again for your responses. I am working in 2011 for this project, the jobs been around for a while. I have verified the path under "setnetworkcatalog" if that's what you were referring to about part catalog. My problem is we have a few projects left under 2011 and just know that I'm going to have to revise more pipe networks. re-install is not an option on account of Autodesk support.
Ok, I replaced the entire C3D 2011 folder that includes the pipe catalog from the my old computer and still nothing. I did notice a message at the command promt that I must not have seen.
"reregistering the control.ERROR: Calculation Failed with Part Table
AeccCircularPvcPipe_Imperial"
I did a quick lookup on this but don't think I feel comfortable enough to mess with registry. Any suggestions are appreciated.
Joe Bouza
