pipe interference
pipe interference
nostupidquestions
pipe interference
nostupidquestions
didn't there used to be a way to show pipe interference in the profile view? i thought that was what the interference check did but it doesn't seem to do that now.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
Hidden_Brain
I recall being able to show interference results in plan and 3D views, but not in profile views. Were you thinking about showing crossing pipes in profile view instead?
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/...
Joe-Bouza
The interference tool only shows graphics in model. It's a shame that bottomed and top of pipe can't be got from it for labeling
Joe Bouza
nostupidquestions
i'm doing a road and drainage project and i have some conflicts with existing utilities and proposed storm pipes. i thought that the interference check would indicate in the profile where the conflict was between the two pipes. i already know where it is in the plan view.
64 GB RAM
C3D 2023.2
Do your check - > it will tell your where and how many in commandline and mark the points in your network.
What you want to do is:
Mark your networks-> object viewer, and then there will be kind of round balls around the points where you have interference!
Funny thing is that most common reason to delays on a site is because interference checks aren´t done propperly, and costly re-planning must be issued.
thank you
