Civil 3D Forum
Part Builder help with conversion of completed object
4 REPLIES 4
Prostang
379 Views, 4 Replies
I have built a complex "part" using 3D elements, solids, and meshes.  Is it possible to create a part out of it?  I attempted to build this using the part builder methodologies, but I struggle with having to have every bit of geometry on a plane.  As you can see from the image, tying the "wing walls" to the end pipe tapers, so attempting to create a plane that bends with the pipe is impossible.  Any help is greatly appreciated.Finished.png
Mike Madrid
Owner, MJM Consulting
4 REPLIES 4
BrianHailey
in reply to: Prostang
Part builder? Nah, don't even go there. Check out the Infrastructure Parts Editor. You can find it in 2019 on the ribbon the same place you find part builder.
You will need to use Inventor to create the 3D part though (Inventor LT will work).
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Prostang
in reply to: BrianHailey
do the Infrastructure Parts Editor parts work in 2018?
Mike Madrid
wpagl452
@Prostang there is a 2018 version of IPE. You can find this if you don't have it at manage.autodesk.com.
All the best,
Winston
Prostang
in reply to: wpagl452
Winston,
Did you accept the solution on my behalf?
Mike Madrid
Rail Community
