Parcel Map Check Report: Setting a point of beginning
tlincolnAY44Q
Message 1 of 9
tlincolnAY44Q
Having some trouble setting a point of beginning for a parcel map check report. The input fields for x and y will not let me manually input coordinates and Civil 3D help says there is an icon that I need to push but I have been unable to find what they are talking about, I appreciate any help.  dialogue.jpg
Replies (8)
Message 2 of 9
rl_jackson
Have you tried setting the POB in the Parcel itself? If it's set there I do believe that report will start from the same position as the Parcel.
Rick Jackson
Survey CAD Technician VI
Message 3 of 9
nostupidquestions
i've got the same problem and i am in the parcel properties. i'm unable to specify the point of beginning either going through the survey map check or the parcel map check.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
Message 4 of 9
rl_jackson
Does the parcel close?
Rick Jackson
Message 5 of 9
Jeff_M
You are editing the POB here?
Message 6 of 9
nostupidquestions
that is where i would set it but it won't let me set it nor does it give the map check analysis. it's been happening on several of my parcel drawings.
64 GB RAM
C3D 2023.2
Message 7 of 9
Dave5Y5NB
How do you get to this dialog box?
Senior CAD Designer
Newkirk Engineering, Inc.
Ormond Beach, FL
Message 8 of 9
Dave5Y5NB
Nevermind, I found it.
Senior CAD Designer
Ormond Beach, FL
Message 9 of 9
eamezcuaB2ZTM
The issue I'm having is that I set it per Jeff's 01-08-2019 11:28 AM screenshot, I hit "APPLY" and hit "OK," but then the coordinates for the Point of Beginning that I JUST SET inexplicably change. This is totally unacceptable.
This happens before I even run a report too - I will return to the properties panel and the coordinates have changed on their own.
I am only doing very basic drafting (or no drafting at all) in the drawing between the time I manually set the POB and the time I notice it has changed. Nobody else is in any other XREF or anything.
