OVERKILL and erasing duplicate entities on different layers
jeff_rivers
Advisor Advisor
jeff_rivers
I have two layers, one contains entities representing every road in the County.  The other one contains entities representing only major roads (arterials, State highways, State freeways).  What I want to do is erase all the lines on the 'every roads' layer that duplicate a major road on the 'major roads' layer.
I've tried using OVERKILL but it's not working.  Where it finds a duplicate line or polyline on both layers, it randomly deletes it from one layer, or from the other layer, so end result is a patchwork where only some pieces of the duplicate roads are erased.  I want it to only delete the duplicates from the 'every roads' layer.  And I want it to delete all of them, not just pieces here and there.
I tried locking the 'major roads' layer but it still just deleted some of the duplicate linework from the 'every roads' layer.
I bumped the tolerance up from 0.0001 to 1.5, no difference.
What am I missing, or is there a better command? A way to do this in MAP maybe?
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
rkmcswain
Not sure this will help, but have you tried the MAPCLEAN command?
R.K. McSwain     | CADpanacea | on twitter
jeff_rivers
That worked perfectly!  Thanks.
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
