Open dwg file vs Paste in New file (Drawing 1) styles and setting
neam
neam
Hi everyone
What a difference between default styles and setting in Open dwg file vs Paste in New file?
Replies (15)
cwr-pae
You are creating new files by pasting an existing file? Autodesk recommends always creating new files from templates to avoid copying errors and other flaws as well a registered apps which eventually bloat drawings to unusability. to transfer data between files copy and paste works for small amounts of data, but using xref/dref or wblock are safer, more efficient methods.
The are a world of settings that don't transfer by pasting, as well as many styles, etc. not associated with objects in the drawing area to be selected will not copy and paste.
neam
Hi
Yes, I pasting to new file (ِpaste.dwg  _Autodesk Civil 3D (Metric) Compelet.dwt).
My question is where to read the current style when we open a file (test.dwg).
Because the styles and setting of these two files are different.
cwr-pae
The commands for new files should open the default template location "C:\Users\<<user_name>>\AppData\Local\Autodesk\C3D 2021\enu\Template" in a standard installation in the USA. These commands are:
typing new at the command line
using the white new file icon
Using the new button on the start page
Using the file menu and selecting new
Using the C3D icon in the upper left and picking new.
You can change, or check the template file location in options under "Template Settings"
neam
It's ok for new file.
When we open the existing file for the first time in Civil3d , the existing style and setting for the opened file is different whit new file.
cwr-pae
Are you needing to import styles into an existing file? Use command 'ImportStylesAndSettings' and find the file you wish to import from.
neam
I am sorry for poor English
NO I don’t want import style and settings i want know why different style and settings between new file and open file
cwr-pae
I think I follow now. When you open C3d you get an empty file (Drawing1) based on the default template named in the qnew line of the template settings in options. If you use qnew to create a new drawing it uses the default mentioned. When you create new file by the other new commands you pick a template that maybe different from the default. When you open existing file it has the template that it was created with plus any imported styles.
As far as  I know, there is no way to determine what template was used to create a drawing.
neam
Thank you very much for taking the time to answer my question
rl_jackson
So if your trying to start a drawing with your DWT or an other you just need to go to the OPTIONS (OP at command line). Got to the template settings, and adjust accordingly. In the image below, you'll notice I have things set to a local drive. I do this so C3D looks just locally no server involvement. When I start C3D it loads my DWT, if I start a new drawing it does the same thing. HTH
Rick Jackson
Survey CAD Technician VI
neam
Hi
When we open an existing file for the first time in Civil3d, the current style and settings is different from the new file (.dwt)
Where does this style and settings set for the opened file (no new dwg)?
rl_jackson
Under OPTIONS you change your start-up dwt (this is in the image), All styles and settings come from the DWT. You can import them into your file "from others" or use a reference template.
Edit: Import Styles and Settings
Rick Jackson
neam
thank you for reply
please open attach files on this post and Compare the styles and settings of these two files.
I have not made any changes to them (style and settings).
I'm familiar with dwt and import styles and setting input.
My question is why the styles and settings of these two files are different.
And where this styles and settings is set for an open file.
I know this styles and settings is set from dwt for a new file.
neam
In paste.jpg, the style and settings is set in my .dwt file, and used which is set for all new files.
In open.jpg, the style and setting is set for the all files that open for the first time in Civil.
Joe-Bouza
paste may bring style but not settings
Joe Bouza
Joe-Bouza
if the existing file never saw civi3d  before and is pure native acad object then it will see the styile and setting of the default template. If it has civil3d objects then there is a fairly good probability it wont
Joe Bouza
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
