CONNECTION BETWEEN TWO DISTINCT ASSEMBLIES
rodolfo.bulhoes92
rodolfo.bulhoes92
Here's  my problem: i have two Assemblies, one on a alignmet and one on another alignment, i've designed the existing road and a new road at it's side, so their daylights should match, but they are currently not atch, there's a way to have a daylight connecting between these two Assemblies?
heres some pictures of the problem.ASSEMBLY TO THE LEFT.pngASSEMBLY TO THE RIGHT.pngGAP CONNECTION BETWEEN  TWO ASSEMBLY.png
Replies (8)
rodolfo.bulhoes92
is there any way i can use those medians assemblys to connect two distinct assemblys?
rodolfo.bulhoes92
A plan view oPLAN VIEW OF THE SITUATION.pngf the problem
sboon
As far as I know there is only one subassembly that can connect two baselines.  LinkToMarkedPoint2 is fairly limited - it can only be used to connect an assembly to an offset assembly in the same corridor.
Steve
Please use the Accept as Solution or Like buttons when appropriate
Edit - the other way to do it is to have one corridor target the other one.  Extract the daylight featureline from your main road, then use a generic link from the side road to target that.
Steve
Expert Elite Alumnus
cwr-pae
Along with @sboon 's suggestion there is LinkSlopesBetweenPoints which may be more suited to your need. AS well as the medians you mentioned. Look at the help (right click in to tool palette or catalog) to see how they function and determine which to try first.
madhu_konga
Try this : From 1st corridor Extract Future line from corridor then offset target to that future line to 2nd Corridor.
Note: if there is no point code to extract future line use marked point
samir.rezk
Autodesk Support
Autodesk Support
Hi @rodolfo.bulhoes92
Depending on the complexity of the design and the goal; one option is to Create a Surface for each Corridor, then use the Paste Surface command to paste both surfaces into a final “third” Surface. The Surface object will automatically triangulate between the two to fill the gap.
hope this helps
Samir Rezk
Technical Support Specialist
rodolfo.bulhoes92
Here's what i did:
With the two corridors alignments i basically prolonged the offset slopes until they intersect, made a 3d polyline from this intersection and targeted it. i couldn't extract a feature line, nor just mae a thir suface, i had this 1:10 and 1:6 slopes i had to attend to, so i guess this solution suited well what i needed!
many thanks for the replies!
rodolfo.bulhoes92
i got the 3d poly line from minimun distance between surfaces, using the corridors top surfaces
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
