- Mute
- Permalink
- Report
In Civil 3d 2018, Whenever I saved the drawing with Geolocation map online data, it works fine and when I close and open the same drawing the geolocation map moved from its original position. The marker position or the fixed position moved either to ocean or to some other country. So everytime I have to set the location and co-ordinates to the required position to keep the overall onlinemap in the desired position. (I desperately need some lock button to lock the map in the desired position before I close the drawing)
If I capture the area using "Capture Area" command under "geolocation tab". Then the captured area of the onlinemap always locked in the original position as required. Meaning, the captured area of the onlinemap is not moving to default position like the overall map.
I have checked different co-ordinate system randomly, checked most solutions given in the Autodesk forum.
I tried reboot everything, I tried different ways of signing in, the problem still continues.
Interestingly this doesn't occur with my colleague's computer who is working in the same server network. (I signed in with my credentials on his computer, the problem doesn't occur - the overall map position is locked to its position after closing and reopen the drawing)
