We have a new and updated server and are installing the 2015 Network License Manager software on the server. A number of network license AutoCAD users have 2010 and 2013 Civil 3D versions on their computer and would like to keep using these versions. Is there anything that needs to be done to link these previous versions to the Network License Manager once it is active?
Thanks for your time.
Solved by AllenJessup. Go to Solution.
Yes, current versions always support serving up valid licenses for older clients. (Note that I said valid licenses. For example, if your license file does not include licenses for 2010, then no version of the NLM will allow 2010 to work)
Strangely, version 11.12.0.0 (a pre-2017 version) was able to serve up 2017 licenses, but there is really no reason to not install the latest.
See also: http://cadpanacea.com/wp/?p=1684
Unless your new server has the same physical address as your old one. You will need to get a new license file. The license file should support your current version of the software and 3 previous versions if you're on Maintenance (Subscription). So what your users will be able to run will depend on what your current version of the software is.
Allen Jessup
CAD Manager - Designer
The license file should support your current version of the software and 3 previous versions. So what your users will be able to run will depend on what your current version of the software is.
Correct me if I'm wrong, but the "3 versions back" part is only true for products on subscription/maintenance.
Also, if @Anonymous has valid licenses for 2010 and 2013, those will also run too, right?
There is no reason he/she can't keep running any perpetual license, provided it wasn't upgraded at some point.
You're correct. I'd already edited my post to reflect that. Anyone should be able to get a new license file for any perpetual network license. If not on subscription it will only be valid for the latest release they have.
Allen Jessup
@Anonymous wrote:
Thanks for the responses. Would we be able to add/combine a 2013 license file to the new license file so the users with 2013 would be able to access the network licenses?
Not if it's from the old server with a different physical address. I'm presuming that if you're on Subscription you're most current version is 2017. You can request a license file for an older version. But it's more difficult than getting the regular license file. Do you have a reseller who can help you out?
Allen Jessup
Yes. Or you could ask them to do it. That's my yearly request to our reseller. We keep a license of LDTC2009 going for converting very old jobs.
Allen Jessup
Thanks. The link I had was outdated. @Anonymous In the table in that link - remember that Subscription is now called Maintenance and Subscription now means rental. You need perpetual network licensed on Maintenance to run previous versions.
Allen Jessup
