Karl,
Here's the steps to using those insane TopoView maps in Civil 3D. You'll just need to change particulars for each map.
The downloads come with a PRJ file and an XML file. Both give you the information you need. The PRJ is a little easier.
PROJCS["GCS_North_American_1983",
GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101004]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-92.1875],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
PROJCS (PROJected Coordinate System) should have a name that is easy to search in MAPCSLIBRARY. "CM-92.1875_Parma" might be a good searchable CS name. Each new custom CS will be easier because you can Duplicate and Edit earlier ones.
MAPCSCREATE in the Planning and Analysis Workspace gives you a nice wizard to guide you through the steps. After creation you sometimes need to exit and re-start to be able to use the new coordinate system.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
