Need to inserts USGS topo map into C3D drawing.
KarlHanson
Message 1 of 19
KarlHanson
I am having difficulty inserting a USGS topo map into my drawing.  My drawing is set on State Plane coordinates.  The USGS topo map is NAD83 with TM projection. https://ngmdb.usgs.gov/topoview/viewer/#13/35.6875/-92.3125 is the link. The header image file is:
2.032
0
0
-2.032
492604.97238
3957790.68834
When I use Raster to transform it gives message "The coordinate system chosen for this image is invalid".  Any ideas how to fix this or what coordinate system I should be using?  Thanks.
Replies (18)
Message 2 of 19
Pointdump
Hi Karl,
The PRJ file included with the downloaded images is nonsense, so the Raster Tools can't figure out what to do. Either change the PRJ file to EPSG:26915 or tell Raster Tools to use only the TFW file.
There's a couple of ways to bring that image into your drawing. Easiest way would be MAPCONNECT. You'll need to Edit the Coordinate System to show the image's coordinate system, EPSG:26915 NAD83/UTM zone15N.
Another way would be to use Attach and Query in the Map Tools.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 19
Pointdump
Karl,
Second way.
Use Raster Tools IINSERT to bring the image into a drawing assigned EPSG:26915 NAD83/UTM zone15N. Save and Close the drawing.
Open a new drawing assigned EPSG:3433 NAD83/Arkansas North(ftUS). In the Map Explorer Tab of Map Task Pane (MAPWSPACE >> Show), Attach the UTM drawing. Query >> Location >> All >> Execute Query.
Dave
Dave Stoll
Las Vegas, Nevada
Message 4 of 19
KarlHanson
Thank you for reply but it looks like the inserted "Shirley" USGS 24K map is inserted in the wrong location relative to the Geolocation online map.  It looks about 40 or 50 miles off.  I have spend a couple hours on this and am stumped. Any other ideas?
Message 5 of 19
KarlHanson
Possible problem found:  when I look at the TFW file the 5th line is the x coordinate of the top left of image, and the 6th line is the y coordinate of the top left of image.
It seems the Y coordinates are correct.  Topo maps that run north/south relative to each other line up nicely.  The difference being about 13,864 meters or so.
But the X coordinates between topo maps that run east west only have a difference of a couple feet.  So they insert essentially on top of each other.  Seems the USGS site is giving away bad data?
Message 6 of 19
Pointdump
Karl,
You're right, and I should have checked this.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 19
Pointdump
Karl,
I see the problem. UTM83-15 coordinate system should have a central meridian of -93. The XML file for the image says the central meridian is -92.3125, even though the map says UTM83-15. That's crazy cakes wierd!
Looks like you'll need to create a custom coordinate system to use this imagery.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 19
KarlHanson
Thanks Dave.  Any advice on how to create a custom coordinate system?  Not really my area.  I'm just trying to make a simple map!
Message 9 of 19
Pointdump
I'll create one and test things out. Results tomorrow morning.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 19
Pointdump
Karl,
I created a custom projection using the information in the image PRJ and XML files. Drawing attached. When you open the drawing C3D will ask if you want to add the new definition. Hit OK. In MAPCSLIBRARY you can see that I changed only the central meridian, from -93 to -92.3125.(Edit: I also changed the extents of Bing Live Maps coverage.) The new coordinate system is named "UTM83-15_USGS-TopoView".
One other way to beat these images into submission would be to use Raster Tools Rubbersheet to make them conform to UTM83-15.
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 19
KarlHanson
Well I still can't get it to work. I insert the topo map and they are still on top of each other.  If the X value in  the header file is only 20 meters or so different then won't the image only be offset 20 meters?  Should be about 11,300 meters, give or take, to move one far enough so they don't overlap.
And also, when I turn on ESRI maps it shows to be in Algeria.  I'm out of ideas.
Message 12 of 19
Pointdump
Karl,
I hear Algeria is nice this time of year. 🙂
I'm not following you. Where are you getting "11,300 meters"? Are where are you getting "offset 20 meters"?
Proof of the pudding is C3D coords matching the map grids. They do for me. Don't go by the TFW file. And if nothing else works for you, use the rubbersheet command in the Raster Tools to geo-reference the maps.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 19
KarlHanson
Dave, again thanks for all this. Could you try one last thing?  Insert the Parma quad next to the Shirley quad we have been working with?  Do they line up correctly?  These run east/west and I can't get to work.  The north/south maps line up together.
Link:  https://ngmdb.usgs.gov/topoview/viewer/#12/35.6840/-92.2328
Message 14 of 19
Pointdump
Karl,
OK, I see what you're saying now. The maps north and south of, respectively, Parma and Shirley, are OK, but not when inserted side by side.
The Parma Geotiffs show a Central Meridian of -92.1875 and the Shirley Geotiffs show -92.3125. Two different coordinate systems. So you'll need to create a second custom projection for Parma. Results in the morning.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 19
KarlHanson
Wow I don't think USGS thought this through very well.
Message 16 of 19
Pointdump
Karl,
It is unfathomable to me why USGS pulled these coordinate system shenanigans. Attached please find another drawing you can use to add Parma's -92.1875 central meridian.
With that you can use either method to bring the imagery into a state plane drawing: MAPCONNECT or Attach&Query.
Dave
Dave Stoll
Las Vegas, Nevada
Message 17 of 19
KarlHanson
Thanks Dave!  Now off to learn  how to make coordinate systems for each map I want to bring into a drawing.
Message 18 of 19
Pointdump
Karl,
Here's the steps to using those insane TopoView maps in Civil 3D. You'll just need to change particulars for each map.
The downloads come with a PRJ file and an XML file. Both give you the information you need. The PRJ is a little easier.
PROJCS["GCS_North_American_1983",
    GEOGCS["GCS_North_American_1983",
        DATUM["D_North_American_1983",
            SPHEROID["GRS_1980",6378137.0,298.257222101004]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["False_Easting",500000.0],
    PARAMETER["False_Northing",0.0],
    PARAMETER["Central_Meridian",-92.1875],
    PARAMETER["Scale_Factor",0.9996],
    PARAMETER["Latitude_Of_Origin",0.0],
    UNIT["Meter",1.0]]
PROJCS (PROJected Coordinate System) should have a name that is easy to search in MAPCSLIBRARY. "CM-92.1875_Parma" might be a good searchable CS name. Each new custom CS will be easier because you can Duplicate and Edit earlier ones.
MAPCSCREATE in the Planning and Analysis Workspace gives you a nice wizard to guide you through the steps. After creation you sometimes need to exit and re-start to be able to use the new coordinate system.
Dave
Dave Stoll
Las Vegas, Nevada
Message 19 of 19
Cadguru42
@Pointdump this is why I love the forums. You should send this info to USGS so they know they've screwed up.
C3D 2024-2026
Windows 11
32GB RAM
