need help with assembly - different slope top and bottom for ramp
jeremie_dupuis-lacasse
Message 1 of 14
Hi, I'm new with civil 3D modeling.  I need to model a ramp that have a different slope for pavement (top) and subgrade (bottom) as shown in the picture bellow:Capture.JPG
I know it's probably something very common but I can't find a solution.  The component that I can't find a way to model is the one in red.  I want a minimum thickness at the minimum thickness point.  I can't input fixed number because my top withd are varying.  So how can I do this?  Wich assembly should I use?  Do I need to build it in subassembly composer?  Any tips, direction to look for will be very appreciated.
Regards
Replies (13)
Message 2 of 14
M_Obradovic
hi,
You can do this using Subassembly composer.
If you can't doing we are here to help you.
in attached picture minimum of thickness is on left side becouse cross slope is -2% of pavement on the right. what happen if cross slope will be -2%on the left side, where should be minimum of thickness(I supouse on the under right curb). Also slope of subgrade always is -3%( what happend if slope of top pavement go more then 3%(I supoused that slope of subgrade follow top slope)
Milos
Message 3 of 14
Ok I have tryed with subasembly composer, I managed to build my component to have 2 slopes.  Now my problem is: How do I use the output of something generated on the left side of the alignement (ex: lenght of right side of component) to be used as an input for the right side component?
Message 4 of 14
Ok I figured it out, thanks for your time, found the solution here:
https://forums.autodesk.com/t5/civil-3d-forum/subassembly-output-parameter-at-different-baseline-sid...
Message 5 of 14
M_Obradovic
Here is one PKT file and inside you can see how you can conrole subgrade slope.
thanks
Message 6 of 14
Ok thanks, I think you sent the wrong package, there is no .pkt in this zip…?
Message 7 of 14
M_Obradovic
Hi
You just have to change extension of ZIP to PKT. becouse forum not allowed to sent PKT extension
Message 8 of 14
Wow thanks for this SubAssembly!  Right now it's far from something that I could do and I will learn a lot from it.  So thanks a lot again for your time and for helping me.
Message 9 of 14
MattCichon
Hi Milos,
there is something wrong with the assy, because I can't load it to my C3D 2018. I get an error - "can't load the subassy script". Or am I doing something wrong?
Do You know if there is a chance to connect such construction layer (the lowest construction layer) with the daylight. Of course the length of the lowest construction layer changes when the length of the shoulder changes. Here's a picture:
Can something like this been done in the SubAssemblyComposer?
Greetings,
Matt
Message 10 of 14
M_Obradovic
If this solve your problem,please click on accept as solution. Maybe someone else have the same problem and can found here the solution.
Milos.
Message 11 of 14
M_Obradovic
Offcource that you can conect lower layer with daylight. Can you open PKT file in your SAC 2018. I create this subassembly in SAC 2020 and maybe from this reason version is not compactibile. Can you try to open subassembly in SAC make save as and try to import again in C3D. If you can do this I will try to help you about your assembly.
Milos
Message 12 of 14
MattCichon
Hi  Milos,
unfortunately I'm unable to open this assembly. I did it your way - I've opened it and saved but it didn't help...
Can You please tell me how to connect the construction layer with the daylight? Is it possible to do it with a basic assembly or just thru the SAC?
Greetings,
Matt
Message 13 of 14
tcorey
If you're using Civil 3D 2018, you must save your subassemblies in Subassembly Composer 2018 or else Civil 3D will give you a scripting error when you try to attach to an Assembly.
It's okay to open a 2020.pkt in Subassembly Composer, and then saveas a 2018.pkt. Civil 3d2018 will accept that.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 14 of 14
MattCichon
Hi Corey,
nope it doesn't work in my case. I open it in my SAC 2018 the "save it as", then opened it again and I still get the error in C3D...
Greetings,
Matt
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
