Need help-conditional subassembly
Neilw_05
Neilw_05
I need to control my daylight catch point. If the catch point falls within the right of way at 2:1 slope then no change req'd. If the catch point falls outside the right of way @ 2:1 then I want to force it to match EG at the Right of Way. However if that adjusted slope exceeds 1.5 to 1 ratio then it should hold 1.5 to 1 ratio until daylight. I am using a generic slope to surface subassembly.
The distance to the right of way varies.
Suggestions appreciated.
P.S. I am not fluent with Subassembly Composer so Out-Of-The-Box solutions preferred.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Mike.M.Carlson
Hello @Neilw_05
I think this one should work for your situation:
Autodesk Civil 3D Help: DaylightInsideROW
https://help.autodesk.com/view/CIV3D/2019/ENU/index.html?guid=GUID-728BF864-F5B1-46B6-92A1-A8B0B88F4...
If not, you could build with Subassembly Composer sort of like what Alan shows below:
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
Neilw_05
It looks like one of the solutions will work Mike. I'll mark it solved if it works after I try it tomorrow. Thanks!
WIN 10 64 PRO
Neilw_05
Daylight Inside Right of Way subassembly solves it. Thanks again Mike.
WIN 10 64 PRO
