I need to control my daylight catch point. If the catch point falls within the right of way at 2:1 slope then no change req'd. If the catch point falls outside the right of way @ 2:1 then I want to force it to match EG at the Right of Way. However if that adjusted slope exceeds 1.5 to 1 ratio then it should hold 1.5 to 1 ratio until daylight. I am using a generic slope to surface subassembly.
The distance to the right of way varies.
Suggestions appreciated.
P.S. I am not fluent with Subassembly Composer so Out-Of-The-Box solutions preferred.
Solved by Mike.M.Carlson. Go to Solution.
Hello @Neilw_05
I think this one should work for your situation:
Autodesk Civil 3D Help: DaylightInsideROW
https://help.autodesk.com/view/CIV3D/2019/ENU/index.html?guid=GUID-728BF864-F5B1-46B6-92A1-A8B0B88F4...
If not, you could build with Subassembly Composer sort of like what Alan shows below:
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
It looks like one of the solutions will work Mike. I'll mark it solved if it works after I try it tomorrow. Thanks!
Daylight Inside Right of Way subassembly solves it. Thanks again Mike.
