Nearmap Images no longer geolocate
jmayo-EE
Mentor Mentor
Message 1 of 28
jmayo-EE
Anyone using Nearmap?
If so have you noticed any new scaling and/or insertion point issues in the past few months?
I can get MSid images in w/o issue with IInsert and a Data Connection. Both of these methods fail with Nearmap images. I have copied the folder locally to insure the path was not longer than 128 characters. jpg and jpw have same name. Fails with company template and NCS template, coord sys is assigned.
This all worked fine for two years and I started to get complaints about two months ago.
Has anyone seen similar issues?
John Mayo
Accepted solutions (3)
Replies (27)
Message 2 of 28
rkmcswain
@Hey @jmayo-EE - we are a user, just not me personally. I'll see if I can get a few sample images to test.
What version of Civil 3D should I test?
Message 3 of 28
jmayo-EE
Using 2020. Thx
John Mayo
Message 4 of 28
Pointdump
John,
Can you post one of your NearMap images that isn't working? I can test in 2020 and 2022.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 5 of 28
jmayo-EE
As requested.
...I am wondering if our MS guys changed our template or acaddoc.lsp settings for insunits or similar variable. I'm busy but will check soon.
The attached files were properly located in a dwg almost 2 yrs ago. I cannot get them in any new file correctly now.
John Mayo
Message 6 of 28
AllenJessup
John,
I didn't catch where you were working and Bing maps won't load. Here's where the image came in.
and the approximate center.
BTW. I left my coordinate system as New York East Feet. That should match NJ.
Allen Jessup
CAD Manager - Designer
Message 7 of 28
jmayo-EE
Sorry folks nj83f is the cord sys
John Mayo
Message 8 of 28
jmayo-EE
The issue is my ignorance. As usual the problem falls between the chair and keyboard. 🙂
I have used mapiinsert with these images for so long and was not aware that data connect requires the user to enter the image coord sys which I never had to do with Mapiinsert....
John Mayo
Message 9 of 28
jmayo-EE
Thanks to all who spent some time on this.
First person who responds with a, 'your welcome' gets the solution!
I can't give them to my own posts. 🙂
John Mayo
Message 10 of 28
AllenJessup
You're welcome. John.
Or maybe 'your welcome'?
Allen Jessup
Message 11 of 28
That's curious. Our ortho photos come in using MAPCONNECT without an assigned coordinate system and they fall right where they're supposed to.
BTW, W74 N51 is up in Quebec in some wild looking country ...
Message 12 of 28
jmayo-EE
I will test David.
Thx.
John Mayo
Message 13 of 28
AllenJessup
Yeah. The Latitude looks severely compromised. But the N/E coordinates looked the be in the ballpark. I didn't test them. Just thought they looked right for West New York, NJ.
Allen Jessup
Message 14 of 28
Pointdump
David,
Location 40.792924,-74.053123 is in Secaucus, New Jersey.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 28
See message 6 of 14 for the coords I was referring to. I was just curious where they'd land.
DAR
Lat45Lon90
(almost, I'm south in Dane Co., WI, that's 100 mi up north in Marathon Co. There's a rock there marking the spot.)
Message 16 of 28
Pointdump
John,
The NearMap image is in EPSG:26918 NAD83/UTM zone 18N, a metric Coordinate System. If you use MAPIINSERT in a drawing assigned that same Coordinate System it drops in the right place. Save and Close that drawing. Then in your NJ83F drawing you can Attach/Query the drawing with the NearMap image.
Dave
Dave Stoll
Las Vegas, Nevada
Message 17 of 28
Pointdump
David,
OK, I see where you got those numbers.
Dave
Dave Stoll
Las Vegas, Nevada
Message 18 of 28
jmayo-EE
Yes the cood and lat lon were in the file names.
Dave S. I know I can get around the units with a query but I have never had to do it with these maps before.
In the zip file is a dwg created in June. It has a Nearmap image that was inserted with MapIInsert. Now I can't get MapIInsert or IInsert to work on the Image. Only dataconnect at this point. Have not tried mapconnect yet.
What happened?
Screencast of IInsert failing. Note the units and correlation values..
https://autode.sk/3y0qsO7
Here's the attached dwg file on the left and the results with a new file to the right.
John Mayo
Message 19 of 28
John,
I used IINSERT in a new drawing, but I did not click the "Transform to drawing's coordinate system" box. Because the image and drawing use the same coordinate system, no transformation is needed. You can also use MAPIINSERT.
Dave (The poster formerly known as Pointdump, who tires of hitting back buttons to be able to post)
Message 20 of 28
jmayo-EE
Thanks Dave.
Odd thing is that works for one image and not another! Just to make sure I'm not going nuts I recorded it. 🙂
https://autode.sk/3mhD4hG
John Mayo
