My main pipe is being treated as a crossing pipe in profile
avanvleckA3DSE
avanvleckA3DSE
I have a WW main that I am creating P&Ps for, and when I go to label my pipes and structures, the profile for the alignment associated with the part, the label is appearing as a crossing pipe and I do not have the option to display the normal profile labels. Any ideas why this may be happening? Is there a way to make the profile consider my pipes and structures as the main pipes and structures and not only crossing? I've attached an example where I am trying to label my pipe as a typical profile label, i.e. "XX.X LF of 8" PVC PIPE at 2.00%" instead the label is indicating the pipe to be a crossing pipe. See example attached as a photo.
-Abe
Neilw_05
It could be your label style settings or you are applying the wrong type of label. Does this happen in other dwgs, or with other styles?  Try running some basic troubleshooting (e.g. import styles from other dwg, import pipes into new dwg, etc.). Can you post your file?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
CivilFlow
Check your profile view properties \ pipe network tab \ override area for possible pipe network style overrides
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
avanvleckA3DSE
I figured out the issue. Instead of clicking on the part and then clicking the add labels, I instead went to the annotate tab and added the label from there. I had the ability to select which style I wanted. It was an easy fix. Thanks everyone who responded.
-Abe
