Civil 3D Forum
MUTCD sign blocks / library?
25 REPLIES 25
Message 1 of 26
deltacoolguy
63006 Views, 25 Replies
I'm looking for a relatively simple, yet accurate, sign library for the common MUTCD signs for plan production.  The sign itself needs to be graphically shown.  For the most part I don't need anything customized.  For some reason, I'm having a hard time finding something that is relatively simple to use.
Also, just curious, if you were doing a plan set with sign graphics, which would you rather work with?  Graphic files (i.e.: jpegs, etc.), or AutoCAD blocks?  I'm thinking I'd rather use AutoCAD blocks, as I could then explode and modify them if I needed to.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
25 REPLIES 25
Message 2 of 26
AllenJessup
in reply to: deltacoolguy
The choices seem to be to get a screen print from the MUTCD or to buy blocks or images. We bought a program that has them as WMF files so they can be used as either an image or CAD.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 26
LeafRiders
We generally use AutoCAD blocks provided from the provincial AutoCAD block library. When custom signs are required we generally snip an image from a scan or PDF and and use that in plan view. (Timesaver). However, if you're trying to establish a defined library of standard blocks, you'll likely need to trace the sign images and ensure sizing is correct. I am not aware of any source that provides the MUTCD signage inventory in AutoCAD Block format.
Message 4 of 26
cwr-pae
in reply to: LeafRiders
I use a set of blocks I created from a dwg originally posted on CAD Block Exchange (I think that's the name, but the site is no longer accessible). I have seen similar things on other sites of this nature.
For what its worth here is the original file.
Message 5 of 26
ACADuser
When preparing signing plans using AutoCad my preference is blocks/dwgs vs graphic/image files. Our current practice is just copying & pasting from other drawings to get the job done. Putting together a complete library has been on my todo list for a while.
Creating your own from nothing will take more time but gives more control over standards and consistency. Searching the internet you can find many sources for files that can be used as a starting point. For instance there is a link to a microstation cel library file on this web page: http://www.wfl.fhwa.dot.gov/resources/cadd/cells/    (Direct download link here: http://www.wfl.fhwa.dot.gov/resources/cadd/cells/signs/Signs.zip).
There appears to be quite a few standard signs in that library. The file is compressed format (Signs.zip) and contains the ustatoin cel library (Signs.cel). Once extracted each cell (named by mutcd code) can be imported into AutoCad using the command DGNIMPORT.  Just be sure to change the file type at the bottom of the dialog to "All DGN Files (*.*)" otherwise it won't show up in the list.  After selecting the file and clicking open you can choosed the desired cell to import. Do this for each sign and save to individual dwg files for importing as a block or if you prefer create all blocks in one dwg file.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
Message 6 of 26
deltacoolguy
I'm surprised there's not a more solid option, even at a nominal price.  I've been doing the patchwork-on-the-fly thing, too, and was hoping to bypass that.  I guess it makes sense why my initial searches came up lacking.
Anyway, thanks to all.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
Message 7 of 26
Here is a drawing produced by the Florida department of transportation withevery sign you might need.  Well maybe not aalllll of them :).  Go to the drawing through the design center and all the signs will show up with the sign name designations.  You also might want to down load the fdot state kit.  The have blocks, subassemblies, pavement markers,  and lots more road stuff.  Most of it is specific to Florida and requires 2015 but there is still lots of good stuff.
Message 8 of 26
Let me be a little more specific. When you are in a drawing and you want to insert a sign block like R1-1 all you have to do is through design center find the downloaded cad file and click blocks. You will find a list of blocks labeled by sign designation in alphabetical order like r1-1, w2-1 ect.  The blocks also have fields in them that you can type your speed limits and other signs that may have different requirements. I hope that is more clear.
Message 9 of 26
in reply to: AllenJessup
Hi Allen,
Regarding the MUTCD blocks, can I ask which program you purchased that provides those as WMF files?
Thank you.
Jason
Message 10 of 26
AllenJessup
You're stretching my memory but I believe it was Sign Works. But it looks like it was sold to a different vendor.
You can download PDF and EPS files from https://mutcd.fhwa.dot.gov/shsm_interim/index.htm
With recent versions of Civil you can import PDF files. There are also a bunch of utilities online to convert EPS to WMF. But since the PDF files are vector based. They should be importable.
Allen Jessup
Message 11 of 26
nwray
I have been looking for a complete sign library for some time, but have yet to run across one.  Part of the problem is that they like to change the standards all the time, and another problem is that each state has it's own version of the MUTCD.  Sometimes the state will eliminate or override federal signs.
I have found that going to the federal or state sign guide is the best way to do the signs.  Just draw them out exactly per the current standards.  You can get the federal sign standards here.  They're pretty well organized, and have all the dimensions you need to draw them up.
If it helps, I have been saving signs as I draw them up into one DWG so that I can use them as blocks.  I don't have a lot, but the file is attached here.
EDIT: I forgot to mention, some of the signs in the DWG are the California versions.  They are noted withe (CA) in the name.
Norm
GIS Specialist
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
Message 12 of 26
in reply to: nwray
Norm,
My versions of C3D (2015, 17) say your dwg was saved with a newer version.  Are you already using 2018?  If so, could you save it back?  I have also been compiling some symbols to use as blocks, but you may be further along than me.
James
Message 13 of 26
AllenJessup
in reply to: nwray
@nwray At the bottom of the page you link is the link to the PDF and EPS files.
Allen Jessup
Message 14 of 26
nwray
Hi James,
Sorry about that.  Here is a saved back version (the next option after 2018 was 2013).  As I mentioned, not really a lot, but it may save you some work.
Norm
GIS Specialist
Message 15 of 26
nwray
@AllenJessup Thanks for that, I missed the link before!
I do sometimes use PDF's if it's a standard sign, but we often have some minor customization that needs to be done (lots of odd variations on "no parking" signs).  Since I have to pass on the signs to our sign shop for manufacturing, I need to have the full sign in CAD so that I can give them all the dimensions.  Usually it's just easier for me to draw it out.
Norm
GIS Specialist
Message 16 of 26
AllenJessup
in reply to: nwray
Yeah. For a one off it's probably easier just to draw it. The PDF import does a fair job of vectorization in 2017. The text comes in as polylines and solids or hatches. I haven't installed 2018 yet so I don't know how well the new OCR in the PDF import works. If it does a fair job. Importing PDF may become much easier.
Allen Jessup
Message 17 of 26
in reply to: nwray
I started from @Anonymous's file, and modified to meet my required criteria.  Turns out I only needed 4 signs out of the whole book.  Fortunately, there were so many in there that you can easily modify them to meet your standards.
Here's my stuff
Message 18 of 26
Update and summary for October 2017:
Partial library of signs in EPS and PDF format (link has been stable for several years).
To get these into DWG, use Inkscape to open EPS file, save as DXF. Then open in AutoCAD.
Updated link to FHWA Cell Libraries (microstation format):
https://flh.fhwa.dot.gov/resources/cadd/wfl/cells/
To get these into DWG, unzip the .cel file(s), rename the .cel to dgn, then in AutoCAD use DGNIMPORT.
Florida DOT has gone DWG and has a pretty good sign library as part of their Civil 3d state kit. Not as true looking. Uses Arial font and sign borders are not really the same. But it's free, and native DWG and has a few signs that I haven't found elsewhere. I also recommend the FDOT fonts as a potential replacement for RomanS/Simplex, RomanD, etc.
http://www.fdot.gov/cadd/downloads/software/FDOT2017CADDSoftware.shtm
Finally, check out this guy's library of signs in SVG format on wikimedia commons:
https://commons.wikimedia.org/wiki/User:Fry1989/Gallery/Road_Signs/United_States
To get these into DWG, use Inkscape to import the SVG, save as DXF, then open in AutoCAD.
I haven't done a proper comparison with using AutoCAD to import PDF to vector.. but I strongly suspect that SVG & EPS to DXF via Inkscape will give you better results. If you have access to native vector formats and programs to convert them, why bother with PDF?
Message 19 of 26
One more resource (and a potential use for PDFIMPORT) is your state (or another state's) standard sign design manuals. For example in Minnesota the MnDOT Standard Signs and Markings Manual http://www.dot.state.mn.us/trafficeng/publ/signsmanual/
Message 20 of 26
I downloaded the .eps file and change the name with .DXF file but it can't open in Autocad, it only shows "Invalid or incomplete DXF input -- drawing discarded.' Is there any other ways to open .eps file in Auto cad. Please kindly guide me.
Rail Community
