Multileader Style - Moving Leader to different location
josephwEPIC
josephwEPIC
Hi, title is kind of vague but I'll explain.
So I made a block that prompts for input and, then I turned that block into a multileader style. However, I'm wondering if there is a way to have the leader change its origin point depending on where the multileader gets moved to.
The image below is the block I made that asks for two attributes to be inputted.
I then turned that into a Screenshot_6.pngmultileader which looks like the image on the right hand side
When I select the multileader and move it around the leader rotates around the first bubble, I was wondering if there was a way to have the leader switch to the second bubble when moved aside and originate from the center of it( Shown in red)
doben
It can be done if "Center Extents" is used in the Attachment tab of the Multileader style manager, it looks like you have it set to "Insertion Point". It will switch sides as you move the multileader however the leader starts at the side of the bubble rather than the center. .
There is a workaround if you want it coming from the center - make a dynamic block with a flip state for the leader. I've attached a sample drawing for you.
MMcCall402
Have a look at using multiple single circle multileader objects and then using the MLeadercollect function to collect them into one object with one leader.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
