Mtext Problem
Mtext Problem
zachLEMHK
Observer Observer
Mtext Problem
zachLEMHK
Observer
Observer
A coworker went to move some mtext in paperspace and the mtext disappeared. We thought not big deal and tried copying in a block of the mtext from a backup copy. Nothing copies in when we tried that . There isn't even an object for the missing text . We have checked font sytles, text size, zoomed extents, etc . Any help would be appreciated .Thanks
Undo/Redo is your friend
ToddRogers-WPM
Can you post the drawing?
Todd Rogers
Civil Administration at Walter P Moore
rkmcswain
Can you create a new MTEXT object? Does it show up?
Immediately after you paste in the MTEXT from the other drawing, run the LIST command, then use "L" as the selection (for the last object created). Does it list the object you just pasted in?
CADobi-wan
My first thought would be a frozen or off layer. Have you checked this?
Please "like" and "accept as solution" if this resolves your problem!
Rob (Autodesk AEC Collection)
Civil Engineering Design Specialist/CAD Manager
www.CADmitment.com
jefflambert9091
Check to see if your text is annotative. If so, check your annotation scales.
Also, I have set my annotative scales and the text did not show up until I got out of the viewport, unlocked it, re-picked the annotation scale of the current viewport.
Jeff
Civil 3D 2024
