STARTUP variable
STARTUP variable
ccookusi
Message 1 of 9
STARTUP variable
ccookusi
When I try to initiate this variable, I get unknown command.
Can anyone else verify this and provide a solution?
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
NVMe Samsung SSD 960 Boot
16 GB Ram
Replies (8)
Message 2 of 9
There is no aecstartup variable in civil 3d.  there's a startup one tho.  Is that what you are after?  What is your desired result from changing it?
Message 3 of 9
ccookusi
In 2019, when I type in STARTUP in automatically switches to AECSTARTUP.
It does not do that in 2018
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
16 GB Ram
Message 4 of 9
tcorey
Use STARTUP, not AECSTARTUP.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 5 of 9
Again, what is your desired result from changing the variable?  What does the 2019 help file say about aecstartup?
I suspect the reason it returns 'aecstartup' when you enter startup is because of Autodesk's tendency to change the format every other release.  #Grrrr  Just my theory.
Message 6 of 9
Todd_Rogers
Do you mean OLESTARTUP, and not AECSTARTUP?
Todd Rogers
Civil Administration at Walter P Moore
Message 7 of 9
ccookusi
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
16 GB Ram
Message 8 of 9
Todd_Rogers
I see what's happening. This happened to me before. It's trying to use Screencast as startup. I had to uninstall/reinstall Screencast. I think this happened to me because I had Screencast installed prior to installing 2019.
Todd Rogers
Message 9 of 9
ccookusi
I tried that to no avail.
Ended up resetting my profile.
That took care of it.
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
16 GB Ram
