Moving Points TO a Surface
Message 1 of 10
I have a surface that was created from survey data. I also have a bunch of points that were collected with a handheld GPS so they are OK horizontally but have no elevation value. I want to determine as accurately as possible what the elevation of these points would be if "projected" up to the surface.
How do I do this?
I am using Civil 3D 2011. Have access to 2015.
Replies (9)
Message 2 of 10
civilman1957
I guess the simpliest way would be to bring the points in, then set your osnap to "node". Go to the "analyze" tab, and click the Inquiry tool. There is a dropdown menu in there. Expand "surface" , and choose "surface elevation and grade" there. Then click nodes...it will display the elevation, and you can jot them down as you go. Note: if you have multiple surfaces in your drawing, you'll be asked to choose which surface you want elevations in.
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 3 of 10
troma
You might want to try the "Elevations from Surface" command.
You'll find it on the ribbon > Modify > Points > (Modify Panel) "Elevations from Surface"
or type the command EditPointSurfaceElevs
Mark Green
Working on Civil 3D in Canada
Message 4 of 10
OK...that works. BUT, I have several hundred points that I need to capture this Z value. Is there a way to "move" the points to the surface, then export the lot and tada...
Message 5 of 10
civilman1957
Ah...you wanted to move them to the relevant surface elevation...then Troma is spot on...
Message 6 of 10
Doesn't seem to work for points?
Message 7 of 10
troma
It's a command for points only, so it doesn't work for anything else!
What specific trouble are you having?
Mark Green
Message 8 of 10
I have nodes that were brought in from a GPS survey all at an elevation of 10 (arbitrary).  I get this message:
Selected entity must be of type: Feature Line, Auto Feature Line, Auto Corridor
Feature Line, Parcel Segment, Survey Figure, Polyline (3D), Polyline, Polyline
(2D)
Message 9 of 10
WAIT! I think have it. Was going straight from Modify to Elevation command instead of selecting POINT first...sorry for the extra help.
But Thanks to everyone
Message 10 of 10
troma
OK, I get you. No worries.
The one I explained is a command that only works on points and won't let you select any other objects. You can specify which points with the following prompt:
Points [All/Numbers/Group/Selection] <All>:
Mark Green
