Multiple Section Views problems
alexsQJTQ4
Observer Observer
alexsQJTQ4
Observer
Observer
I am trying to create multiple section views for 42 samples lines. After I get all my settings picked out within the wizard I click create section views, then i specify where the section view origin will be. As soon as I click on the screen it locks up and I get the whole "not responding" thing and i have to force close autocad. So I tried it again but deleted half of my sample lines. This time it worked without a problem with all the same settings.
Is there a limit to how many sample lines you can cut at once?
Also I am using Autocad Civil 3d 2014.
Jay_B
I'm not sure if there's a limit, but if there is, 42 is nowhere near the limit.
After deleting 1/2 of the sample lines and getting it to work, did you try it with the sample line range which was deleted?
With corridor & all corridor surfaces displayed, view the Corridor in "front" view.
Any lines or "waterfalls" going from the project datum range to zero elevation?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
