- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When modeling corridors I have always had an issue with how to model a transition in a retaining wall.
The attached image shows a trail corridor.
- The trail and shoulders are 1 assembly using a centerline alignment as the main baseline.
- The connections to EG (both left and right) are using corridor feature lines as baselines in order to set regions independent of the centerline assembly. This gives more flexibility for placing retaining walls.
- The shown connections are a link slope to surface at 3:1 and a retaining wall. There is no gap in the regions from 3:1 to retaining wall.
- The entire corridor is 5' of fill above EG.
I want the retaining wall height to taper from the connection to EG, upward to meet the point where the 3:1 assembly and the wall intersect, at a 3:1 slope. This is a very common occurrence in these types of projects. In the past I have tried a couple things. I've ignored the surface and just drawn polyline contours. I've made a gap in the 3:1 and retaining wall regions, then manually created a transition using feature lines and adding them to the corridor surface. Both of these options require a lot of work and are not dynamic with the corridor. I'm looking for a better way.
I have seen videos from Jeff Bartels showing ways of creating transitions in corridors (links below) but I don't know if I can make these options work for a retaining wall transition of this nature. If someone knows how to make these work in this application, this would be ideal because they would be dynamic with the corridor.
Jeff Bartels Applying Transitions to Virtually Any Civil 3D Subassembly - https://www.youtube.com/watch?v=W-f4Ep7TXyE
Jeff Bartels Modeling a Civil 3D Corridor with Variable Slope Daylight - https://www.youtube.com/watch?v=NKyTjaUL3J0
So my question to everyone is, How do YOU model retaining wall transitions?
