Missing Material in some sections
 In some cross sections, the material is missing (note the lower cross section). I searched this out, and apparently this has been an issue since 2014. I have tried the solution offered on one of the forums (adding additional data at the intersection points between the surfaces) with no luck. has anybody found anything else?
Replies (20)
tcorey
If I had your drawing, I would look for places the surface sections don't make a closed boundary.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Thanks for taking the time to reply, Tim. I have some other sections in the same group where the two surfaces definitely don't intersect (for instance, where the design surface doesn't reach the original ground) and it still drew the material on those sections, so I'm thinking it's something else, at least in my particular case. I continued to search online after I posted this, and I found a comment that said it could possibly be the sample lines, and you can find out by moving them. So I moved one of them 1m along the alignment and the material appeared in the section. I had 18 sections with no material so I began moving each of them and I found that some had to be moved down-chainage to make it work (most of them appeared when I moved them up-chainage). Also, the quantities appeared in the table. I honestly have no idea why this worked, but it saved me from drawing 18 areas manually and calculating the volumes, so I'm very happy with this. It only took 5 mins. to move the 18 sample lines, so at least it's a timely solution.
Have a great day, Tim
Jeew-m
I find this could be helpful in accurate section views. may be helpful here also.
https://www.youtube.com/watch?v=Zf3Y-xN92DY
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
lim.wendy
Hi @Anonymous ,
Thanks for posting your question and feedback. I can confirm that this is still being researched by the development team. I worked on similar issues before and what I found was if there was a boundary added to the surface, it may cause some materials to not show up, and the way around this was to edit the surface near the cross section where it's not showing the material.
For example, try these:
  • add a point at the intersection where the sample line crosses the border of  your surface and apply an elevation to the point.
  • Swap surface triangle at the area where the materials are not showing
The development team is aware of this issue and working on a fix, but I hope you are able to get the material show up based on the workaround above. Apologies for the inconvenience caused.
Let me know how it goes...
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Thanks, Jeewana, I gave it a look.
Pat
Hi, Wendy
I got the materials to appear by moving the sample lines by 1 meter along the alignment, which allowed me to get my tender quantities out on time, but I realize that it's just a workaround, and I haven't solved the problem yet. You are correct about the boundaries, as I put them on all my surfaces. We share surfaces by XML in our department, so if I don't add a boundary it regenerates and makes all the long triangles again. Now that the contract tender has gone out, I have time to play around with this a bit more, so I will try your method on my original drawing to see if it fixes the issue.
Thanks for the info,
Pat
lim.wendy
Hi Pat @Anonymous ,
Let us know how it goes... I'm glad that you were able to get your tender quantities out on time. 🙂
Wendy Lim
Rails Summit
Coffee_Aided_Design
I tried all of these methods and moving the section lines did indeed work. Interestingly,  shortening the sample line width also worked. The triangle swap didn't do anything but adding points around the problem area did. My original surface did have a hide boundary but the problem persisted after removing them. I'll attach the file if anyone wants to reference it.
Regarding intersection and closed boundaries: Can someone tell me why intersections and closed boundaries get brought up as a reason for these types of errors? As far as I can tell, Civil 3D seems fairly robust and doesn't require closed boundaries when calculating materials using earthworks material calculations. I did some cursory tests (admittedly small triangle counts) and my cross sections handled fine with open/closed, intersecting/not, and surfaces with holes (file attached).
Who knows what the problem is but I'm am glad it is being worked on. Thanks all!
Coffee_Aided_Design
Hello Wendy @lim.wendy,
Is it possible to get an email notification when a future update solves this issue? I would like to know when to bother our IT department for an upgrade 😉  Thank you for your help.
lim.wendy
Hi @Coffee_Aided_Design ,
From the development write-up, the issue is fixed for C3D 2020.5.1 and C3D 2021.2 update.
Are you still seeing the issue in both updates?
Wendy Lim
Rails Summit
I agree with your comments about the boundaries. I can't see what that would have to do with whether the materials are displayed or not. Usually, wherever a surface ends, like where you don't have quite enough surface to cover, the program just draws a line there and displays the material, it doesn't need the surfaces to close. In any event, the development team seems to be working on it. Have a good one.
Pat
Coffee_Aided_Design
I was able get the newest update installed by our IT department. Seems to have fixed the problem. I did have to run "Compute Materials" again to refresh the sections. For those who are curious, I was running C3D 2020.2 and am now on 2020.5.2
abdelali.fettachLRR4T
Observer
Observer
Hello everyone, I'm using civil 3d 2021 and i also have the same problem, at some sections the material is not visible, the solution i habe found for the moment is to move tha tab linen. apparently the audodek technical team habe still not succeeded in resolving this defect.
David.Jorge9EYR8
I am running the latest version of Civil 3D 2022 and the same issue occurs.
I cannot shift the sections as I need them at specific Chainage positions.
Does anyone know of a fix for this yet?
t_kraus6CZUL
Community Visitor
Community Visitor
I am running Civil3d 2022 and have the same issue, any fix yet?
sbrasher
I am running Civil 3D 2023 and this issue is driving me absolutely bonkers. I have hundreds of cross sections and some of them refuse to show the material. I've spent hours adding points, removing boundaries, swapping edges, ect. Eventually, something works, but I don't have the time to keep doing this. Is there any solution Autodesk??
David.Jorge9EYR8
As I posted above, my problems persist as well, now also with 2023.
No solution has been posted here so far, however, I have found a "workaround" that seems to work at least for the majority of the projects I have worked on (some simply just don´t).
When comparing surfaces for hatching, if the top surface is extended to intersect the bottom surface then the correct area will be hatched and area volume calculated (this is also an issue, it is not just graphic representation of the area).
Usually what I do is I save my finished model with a new name and extend the surfaces so they intersect, usually the modeled surface past the existing terrain or previous layer of material.
Hope this helps.
hallvard_skrede
I had a similar issue, where the problem was that no material showed up at all.
The material was based on 3 surfaces, and somehow, that wouldn't work: 1) terrain model, while 2) and 3) were two separate parts with cuts in the terrain. The solution was to make a material for each of the cuts...
Regards Hallvard
Richard_Mehall
Please tell me there is a solution to this.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
