I'm using Civil 3D 2013 and when I perform a Mapcheck and print out the report, I get information that I don't want in the report such as Deflection Angle, coordinates for Radius points and such.
How do I remove those from the report?
@Anonymous
I did a bit of research on your question and what I've found so far involves editing files such as style sheets and vba projects. The only editing functionality I found within Civil 3D is being able to change units. Here a few links that describe where to making edits to reports in Civil 3D.
About the Reports Manager
Customize Your Civil 3D Reports
http://blogs.rand.com/civil/2011/03/customize-your-civil-3d-reports.html
Civil 3D - Report Customization
http://blog.civil3dreminders.com/2011/03/civil-3d-report-customization.html
XML Reporting
http://blog.civil3dreminders.com/2011/02/xml-reporting.html
XSL Reporting
http://blog.civil3dreminders.com/2012/02/xsl-reporting.html
Because you are using version 2013, you should already have the VBA module installed. For anyone using a later version of Civil 3D, you'll need to download and install the VBA Module for Civil 3D. Make sure you download the correct version (C3D 2016 64-bit is the one I tested).
Download the Microsoft Visual Basic for Applications Module (VBA)
If you still have questions, @Civil3DReminders_com may be able to provide additional direction.
[UPDATE: Added information about 2013 having VBA module already installed.]
Tom Richardson
CAD Manager
Crossing the line with Civil 3D
Twitter | LinkedIn
If you find an answer to your question, please mark Accept as Solution so others can find it as well.
Kudos are appreciated too.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
