@Joe-Bouza
<<...does FDO connect to the excel?>>
No, it doesn't connect per se.
AutoCAD will use a Windows thingy called an ODBC. This Windows thang is the mechanism that allows Microsoft and Autodesk to communicate. Without an ODBC that data won't move from one to the other cuz they won't be able to see each other's business. No not that kind of business, data business.
On top of that, your data must have a KEY that links both files. For example, you may have an existing homeowner list compiled by the Tax Assessor. The assessor used his data to create a shapefile with owner name, street address, parcel PIN, square footage, tax rate, and tax amount. You also have a second list containing names, home addresses and phone numbers from the local school district.
You may link the phone numbers with each resident using the street address because the address appears in both lists. You are fairly confident it will work because it's unlikely two homes will have the same phone number. If, however, your data was jacked with specifics, maybe if both lists contained parcel PINs, then you'd be extremely confident since every home has a 'unique' PIN. Y'know some homeowners might not have a phone (or have a very private number, Hollywood style).
An ODBC would be able to LINK Autocad Data to an external file such as one in Excel or Access format.
If you really want the ODBC driver, you can read about and download the Microsoft database engine >>HERE<<
ODBC info from Autodesk.
If you work in a firm with an IT department that values security, you might not be able to install the driver without their consent. In some firms you cannot install a mouse driver or a new font without putting in a ticket with IT. Even worse is installing the ODBC driver itself......it's a BEAR and appears to require some IT-geeky-know-how in order to wade through the security stuff. Be forewarned.
Chicagolooper
