Sheet Set Manager Import Layout as Sheet
scurtisWN7SY
scurtisWN7SY
I started a project in C3D 2022, set up in SSM and have all functionality when I open in 2022.  I am changing to C3d 2024 and when I open the project and open the dwgs in 2024 I created a new layout sheet and tried to add it to SSM but "Import Layout as Sheet" was greyed out.
Is there a compatibility issue between SSM in 2022 and 2024?
user181
I have no issues going from 2022 to 2024. Did you make sure to save the drawings after making the layout?
Also make sure you have the sheet set open in the SSM palette.
scurtisWN7SY
I found a set variable  SSMDETECTMODE that was set to "On" so SSM for Web kept opening.  I changed the set variable to "Off" and opened the .dst again and SSM opened correctly.
VincentSheehan
Make sure the SSM is not locked. If it is, remove the lock file in the same folder. You may need to unhide it.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
