Manual point creation
Message 1 of 9
When Creating points manually, next to the center of the crosshairs is a small box that displays the description I'm typing in, or the previous description, and the elevation I'm assigning.  That box has disappeared.  How do I get it back?
Replies (8)
Message 2 of 9
wfberry
Try the F12 key on your keyboard.
Bill
Message 3 of 9
When do I hit it?  I tried before and during, and nothing happened.
Message 4 of 9
wfberry
The F12 key is what I use to switch from data entry at the cursor to data entry at the command line.
Frankly I despise the data entry at my cursor.
Bill
Message 5 of 9
I get neither.  I only see what I entered after the point is created.  What happened and how do I get it back?
Message 6 of 9
user181
Hi @Anonymous,   Try setting your DYNMODE variable to 3.
Message 7 of 9
It magically returned on its own.  Thanks for the suggestions.
Message 8 of 9
user181
You can also turn the setting on and off with DSETTINGS command and on the Dynamic Input tab select the Enable Dimension Input where possible box.
Message 9 of 9
rl_jackson
I believe this is a bug and it been around for a few releases. It will also appear when you use the alignment or parcel tools
Rick Jackson
Survey CAD Technician VI
