When Creating points manually, next to the center of the crosshairs is a small box that displays the description I'm typing in, or the previous description, and the elevation I'm assigning. That box has disappeared. How do I get it back?
The F12 key is what I use to switch from data entry at the cursor to data entry at the command line.
Frankly I despise the data entry at my cursor.
Bill
You can also turn the setting on and off with DSETTINGS command and on the Dynamic Input tab select the Enable Dimension Input where possible box.
Rick Jackson
Survey CAD Technician VI
